Hello all,
My ole reliable TO30 is giving me a problem this spring. TO30, 12 volt conversion with alternator and solid state ignition. Fresh battery. Shows 12.6 volts at the batt terminal on the start switch, but only 3 volts at the ignition terminal on the switch with the key on. Good voltage down on the bell housing and across the old original amp meter. Wont even click the starter. The ignition switch checks out ok. Any ideas?
