steve19438
after putting remaned carb. on it still would not start. new plugs same thing. ordered a new set of SP wires. put them on a little while ago, charged the batt. then turned the key; pulled the choke and it fired up.
oil pressure is only 20 lbs. but I am hoping that is because there is a leak where the oil line connects to the gauge. does not have live hyd. or pto but the hyd. seem to work ok. no chattering or other goofy going ons.
pwr. steering seems to work ok too.
only odd thing I noticed is the distributer shakes but it does not seem to be loose.
brakes ok too.
bought this at a JD dealership last fall.
brakes ok too.
