Hi Chaps.
Pete again, Righto sorting out the problem with my gear stick starter. Pulled it apart and cleaned it all up. It s all working on a multi meter. starter was no turning and you could hear it trying to turn and smoke was starting to appear at the switch on bell housing when engaging the starter on the gear stick. so lloks like the starter has gone bad.
So removed starter and connected to a battery for testing. It was pulling the battery down to 2 to 3 volts on the battery. And would cut out after 3 sec or so.
Can you services theses guys or any hints what to look for.
Cheers
Cheers
