steve19438
1.is this rotella the correct stuff?
2. since ferguson specifically stated to use NON-detergent oil in the early fergusons is it safe to assume detergent oil was available back in the 40's, 50's and 60's?
3. oil has come a long way in past 50 years or so so is it safe to assume oil filters have improved as well?
4. have oil filters manufactured today for these old machines come as far as improvements to modern oils? what I am getting at is if oil filters made today for these old machines have NOT been improved should we really use detergent multi vis oil in these old engines. the way I understand multi vis oils is that as the engine warms up, thereby warming up the oil, the additives added to multi vis oils makes the oil go from 15w to 40w. once the oil gets to 40w will it pass through the oil filter as a 20 or 30w oil would thereby leaving the contaminates behind in the oil filter.
thanks!
thanks!
