Thanks Inno. fortunately I do have the dual clutch.. Ive heard some stories of guys going thru objects because of the single type clutches.(quoted from post at 14:36:37 04/24/15) If you don't have dual clutch, the spinning blade of the Brush Hog will continue to turn your rear wheels even when you push in the clutch. There is so much momentum there that it is impossible to stop the tractor. An over-running clutch attaches to your PTO and the shaft of the brush hog into the over-running clutch. It only spins in one direction, the direction of drive from the PTO and will not allow the PTO to move your wheels when there is no input from the tractor thus allowing you to stop.
