2tractors
Finally got around to sticking some plants in the ground last Saturday with the 50 pulling the plow when all of a sudden started getting smoke from the front of the engine and lots of it. Luckily it wasn't anything major. Let's hear your guesses of what it was.
An armadillo stuck in the fan belt?
A can of Carling Black Label wedged between the pulley and the block? ... oh that one ain't as likely as the armadillo..
One year was plowing with my D14 AC tractor, it started missing, I looked at everything.
Finally took the side panel off located under steering column, big mouse nest, they had eaten the insulation off the wiring,
Each time I hit a rough spot, the wires would swing over and short out against the steering column.
Small animal, but they can sure make a mess of things.
How about the air cleaner was not tightened correctly and it came loose and the oil from the cleaner got sucked through the radiator onto the hot engine?
Oh I got it now! An armadillo got ahold of your wrenches and stuck a 23C in there when you weren't looking. sneaky little things, got to lock up the tools, can't trust em.
Well the armidildoes only come out at night but that was way funny, Tony should be a writer for Saturday Night Live but
Gov 35 got it right. You win an authentic leaking petcock for your 35 standard petrol. I took it off mine and went with
a ball valve.My email is open if you want it. Congrads!!
