Tom Bowman
If you've just finished re-torqing the head and re-adjusting the valves on your TO-20, and hear a horrible jangling metallic sound from the front of the engine when you start it up: (1) walk to the front of the tractor; and (2) remove your homemade crank handle from the crank pulley, where you were using it to turn the engine by hand to set the valves.
Probably nobody other than me would ever need this tip!
No harm done, thanks to the fact that the handle disengages from the crank pulley when the engine starts.
