Jeremy in DE
For a bit now whenever I start my TO30 it runs well for a few moments, but then stutters and dies. It's fuel related I'm nearly certain, because if I check for fuel at the carb it doesn't flow (either not well, or not at all). I've learned to disconnect the fuel line at the sediment bowl. It will usually drip a moment then start flowing. After that I reconnect the line and the tractor runs fine for as long as I need it to run.
I have always shut the fuel off when the tractor isn't running.
I've cleaned the sediment bowl assembly. That seems fine. I have added an in-line fuel filter that I thought was the problem at first, but I can disconnect ahead of it and still the fuel doesn't flow at first, then drips, then flows well and after that the tractor runs.
What am I missing?
What am I missing?
