I have an MF35. SN is SGM 248755. Looks like it takes distributor 194058M91 (AGCO part#) or 1112643. (Delco-Remy part#)
I was looking at putting this electronic ignition conversion kit in it:
http://www.yesterdaystractors.com/Massey-Ferguson-135_Electronic-Ignition-Conversion-Kit-High-Perfomance-12-Volt-Negative-Ground_91145A.html
My concern is a note in the listing which says "Ignitor II applications can not be used with solid core ignition wires, can be used with our ignition wires p/n S.66442."
So I have a look at their ignition wires:
http://www.yesterdaystractors.com/S66442_Spark-Plug-Wire-Set-4-Cylinder-Universal_22193.htm
If they're only $10.86 they surely aren't anything special. The ones on the tractor came from a car parts place, and are a similar "universal" 4 cylinder set.
How do I know if there's a conflict with the wires I have?
