I was pulling some small trees out and everything was working fine. I made a right turn and when I tried to straighten out by turning the steering wheel to the left the steering wheel turned real easy and the steering shaft started to screw itself out of the steering housing. If you turn the wheel to the right it will try to turn the wheels right, but if you try to turn the wheels to the left the shaft unscrews and the wheels don't move. Both of the pitman arms move correctly to the right, but don't move at all to the left.
I've never had the steering box apart, but looking at the shop manual I don't see any retaining nut or bolt to keep the steering shaft from unscrewing. Has anyone had this problem before or have an idea as to what may have happened? Thanks for any help.
Bob Mc
Bob Mc
