Found TO-35 for sale on Craigslist for $1500. Drove an hour with trailer to see it. Strange beast. Loader brackets still on front axle and under rear fenders, but loader gone. Gear lever cocked to the left; all gears work well, in both high and low, but shift lever is sideways. Tractor starts and runs well, steers well, brakes so-so. Tires ok. Has genny, but no wiring. No harness, nothing hooked up except battery, which of course doesn't charge and can't test genny. No gages, but seller has new gages to go with it. Hydraulic oil has lots of water in it, and lift chatters some. Now here are the kickers: distributor is not delco and I can't figure out what it is. Points are like nothing i've seen. Carb is not M-S and I can't figure out what it is either. Seller bought tractor cheap and with no hood, which he has installed and got cold feet on fixing it up. He does not know any history. Serial on dash is screwed on, not riveted, which leads me to believe it was moved. It shows serial 154,000+ which should be a '55 I think, but I don't trust it. Maybe an industrial model? Any thoughts?
