TO 35 carburator
Ron Zega
New User
I recently bought a 1956 TO 35, according to the serial number, the green and beige one. I put in all new ignition parts. It fires right up but the idle is a little rough. I don't have a manual yet, so can anyone tell what me what carburetor make is on it? It is the Continental 134 engine
it might be one of the more rare early 1956 models, some were painted green body with beige sheet metal.
i understand that sometime during 1956 they changed the color scheme to gray body and beige sheet metal like my 1957 model, the ferguson name plates should have green background color.
the owners manual that came with our tractor is dated 1956 and it appears to have a tractor on the front that is painted green body and beige sheet metal. but their printing back in the day was not that good, so who knows, i do keep the manual under cover, do not use it to maintenance the tractor.
if your tractor is truly an early 1956 model painted green body and beige sheet metal, i would think long and hard before you repainted it red or sum such.
please post some pictures of it!!!!!!!!!
Normally Marvel-Schebler carb, unless someone replaced it with something else. Sometimes these tractors have Zenith or even rarely Carter carbs on them, but the M-S is the common standard. Carb kits are available from this site and many other places.
(quoted from post at 14:04:51 03/17/15) Normally Marvel-Schebler carb, unless someone replaced it with something else. Sometimes these tractors have Zenith or even rarely Carter carbs on them, but the M-S is the common standard. Carb kits are available from this site and many other places.
must have a rare one.....mine has a Carter.
