TO 20 has old 12 volt conversion. Ammeter indicates it is not charging. I need to verify wiring from the alternator to the voltage regulator. 3 wires from the alternator: from Bat (red terminal) to Ammeter (green wire), from FLD (white terminal) to S on voltage regulator (yellow wire), from STA (black terminal) to A on voltage regulator (white wire). Wire from I terminal on voltage regulator to ignition switch. There is also an F terminal on the voltage regulator to which nothing is connected (it is rusty looking).
My concern is whether the A and S terminals are correctly connected to the alternator (they got bumped and disconnected and could be switched or moved).
