I recently installed an electronic pointless ignition conversion
in my 1950 TEA-20, with Standard Engine (Lucas distributor)
It has been changed to 12 volt/ neg ground.
During the change-over I found that 1 of the springs, attached to the advance weights , was missing and the other spring was
attached to the post end only, the other end having been broken
off.
Even tho I can start the engine it does not run even,probably
due to the lack of the advance-weight-springs.
My question: where should I search for information/specifications/
and/or purchase of replacement springs.
Any help will be much appreciated.Thanks for prompt reply (s)
Ron_m
off.
Ron_m
