MF35 Power Steering Leak
Jeremyth
New User
I spotted a similar post from 2014 but was unable to reply to it as it had been archived. I am having the same issue on a MF35 I purchased recently that is leaking power steering fluid out of the top of the steering column. Very new to this and any help would be greatly appreciated.
There is a seal in top gear box that has to be replaced. You might try P.S.Stop leak. I have TO 35 that is leaking but have not taken apart. Seal is just a few $. Have to take dash, steering wheel off to repair. Go AGCOPARTS BOOK view as guest click on 35 MF to see picture.
Thanks Minor. Is there any guide to doing this ? Already taken the wheel off (which came off easily) unscrewed the dash and can access the three bolts in the housing - tractor has been painted recently so the housing is thick with paint and will need working loose. No idea how to get the dash off though. That looks a little more complex.
Take wire off gauges unbolt dash and slide up off steering tube. Take 4 bolts off bottom steering tube to get to seal. Look at AGCOPARTS Book as guest to see picture of break down.
