steve19438
sometimes you just gotta love these old machines. it is a balmy 37 and the sun is shining so I decided to see if I could get one to-35 in the garage. it has not run since just before Christmas and it started on the third starter button push. I guess it helps that it is 12V but I was pleased.
The TO's do start easy!
I like to play the game with mine, turn on the gas, set the throttle about half way, pull the choke, turn it through one compression stroke and get off the starter. Nine times out of 10 it will start, even when it used to sit outside for 6 months at a time!
It is 12v, from the factory, still has a generator, still has points.
