safety start linkage
figured out why my safety start doesn't work, they bent the one guide so the shifter wouldn't go in and the linkage is gone solenoid probly doesn't work either. wondering if someone could post a picture of what it looks like so I could fab it up or maybe someone has the parts?
If interested, I have all these parts from my parts tractor. The starter link is easily made as it is just a piece of plate steel with two holes. The cast rocker and the shift fork would be the hard ones to make.
The switch is available as an aftermarket piece, although yours be ok. Use a continuity tester and see if the circuit will close.
Jeff
TE20Ferguson at aol.com
Here is what the inside of the switch looks like. The second image shows the rocker arm that is missing from your tractor. (the line is ties to the starter link)
