OliverNate
getting going again on my TE-20 project and have a few questions, by the way I do have an operators manual and shop manual but there are kinda vague and the one valve isn't in either book. So on the valve can this be setup to run a one-way cyl? I would assume you pull the lever up it would supply pressure and put the lever down to push the button it would relieve pressure? probly would have to remove 3pt arms cause the would go up and down.
Next is the draft control spring the book says this turns so you can adjust it and mine is stuck so does the whole thing have to come apart to unstick it or is there a trick?
Third is the safety start. This one was setup with a button on the dash ever since dad bought it but the safety start switch is on it but you can't put the shifter in the S on the gear pattern. Is it possible something is broke or can you lock out this feature? I would like to fix this feature so incase the safety start switch is bad do they make new ones some place?
Sorry for being long winded but this project has been apart to long and would like my fergy back.
