Dearborn Dozer
Tom H.
I picked up this plow setup a few weeks ago and finally got it set up to use. With the exception of the lift bar and cables it is all original. Not Ferguson but it does a nice job plowing here in the northeast.
can you show how it lifts? i cannot see it in the pictures. i have a plow blade i want to put on my to20 but need to see how yours works.
Here is the lift bar across the two lift arms. It pulls on cables
that lift the front of the frame while the back pivots under the
fenders. There is a manual posted on the N Fords site that I
uploaded which was very helpful.
Here is another option if you have this style
drawbar. It's a single cable pull. If you are
building a frame or piecing together an old truck
frame this might work for you.
Kirk
