Hydraulic remote question
Hello again. Found this hydraulic remote on a Massey in a salvage yard. Would this fit on my mf35? Is it for dual acting cylinders and if so would this run two of them? Last question is to how much to pay for it? Sorry for the bad pic.
Thanks
jason
Hello Jason
Yes this valve will work on your MF 35. It will only run one cilinder , the other handle is used to run the three point. I have seen these valves sell for three hundred dollars plus . They were a vary expensive valve when they were new. The nice thing about them is you remove the transfer cap on the tractor and bolt it on and your are ready to go.
Good luck Lance
One is a selector valve, other runs a remote two way valve. took one off my 150. because I needed two double acting remotes for the V rake. Sitting on a shelf in my shop, in Canada
(quoted from post at 08:44:05 01/20/15) Hello again. Found this hydraulic remote on a Massey in a salvage yard. Would this fit on my mf35? Is it for dual acting cylinders and if so would this run two of them? Last question is to how much to pay for it? Sorry for the bad pic.
Thanks
jason
