Correct oil pressure for a Z134 Continental
dwaldro
TO35 with Z134 Continental. Just got it running. Oil Pressure showing to be about 20 lbs. Is this about what it should be? I've changed the oil and filter.
thanks
Book sez... 20 to 30 PSI at 2200 RPM and not lower than 15 PSI at idle.
I'm assuming this is at operating temperature, doesn't say what weight oil, probably straight 30.
The 15 PSI at idle sounds a little high, especially with light or multigrade oil. As long as you have "some" pressure at idle, should be OK.
