Hyraulic cover removal
sv_morris
re: ferguson te20
Hi All.
Please could someone tell me how to disconnect the hydraulic valve from the control fork so that I can remove the hydraulic top cover? I have removed the side inspection cover but i'm not sure where to disconnect. Any help greatfully received!
Thanks
Steve
As you look in from either side you will see a bolt on the fork
that is attached to a block. Remove these bolts and the forks
can be spread apart to release the valve " T". Reach to the
bottom of the fork and you will see/feel it. Open the forks and
it will come out, leave it thereand you can now remove the
cover. Just had to do this with mt TO30.
