Grandfatherjim
My charging voltage is low, at about 12.2. I suspected the regulator so took it off and checked the resistance across the points, and it was high and inconsistent one time to the next.
In order to get better access for cleaning, I absent-mindedly unbolted one piece that holds the fixed point above the moving one, and now realize that I get to set the points gap on reassembly.
I've looked around the web and cannot find the spec. Anyone know it?
It's a Delco, 12V, negative ground, 1958, TO-35.
Thanks
Thanks
