Massey TO30 and Ford 8n hydraulic pump
ClayC
New User
I have been trying to find a replacement hydraulic pump for my TO30. I have been unable to find one. While looking I noticed that a lot of the repair kits for the hydraulic pumps listed the Massey TO20/30 and the Ford 2N, 8N, and 9N. Are these pumps interchangeable? They look very similar. Even the mounting plate on the bottom appears to be the same. I've found quite a few Ford pumps for pretty cheap, but need to know if they'll fit before I buy one.
I have a parts TO 20 & TO 30. I believe both still have the hyd
pump on them if interested. The 20 was a runner with a
cracked block. Don't remember on the 30.
(quoted from post at 14:09:32 01/10/15) I have a parts TO 20 & TO 30. I believe both still have the hyd
How much?
(quoted from post at 20:32:08 01/10/15) I have been trying to find a replacement hydraulic pump for my TO30. I have been unable to find one. While looking I noticed that a lot of the repair kits for the hydraulic pumps listed the Massey TO20/30 and the Ford 2N, 8N, and 9N. Are these pumps interchangeable? They look very similar. Even the mounting plate on the bottom appears to be the same. I've found quite a few Ford pumps for pretty cheap, but need to know if they'll fit before I buy one.
You can use the pump out of a Ford 9N or 2N but not an 8N. The 8N hydraulics had position control so the pump and linkage is different.
The Fergy TO-20 was the basic pump. It also fits the
Ford 9N and 2N. It will also fit the TO-30.
If you have an 8N you can have position control by
changing the top cover and the 8N pump into the TO-
20/30. I currently have an 8N on the tear down that
will lose it's hydraulics the the Fergy.
Another project.
Do you truly need a full pump?
These pumps are an easily re-build. All parts are
available.
The blue shop service manual has all the
inspection dimensions and all the parts are
available from Bearco, Sparex etc.
Jeff
