C. Amick
This is not much to go on, but my uncle had a gray Ferguson tractor that had really skinny front tires. Seems like they were no more than 4 inches wide. I think it was a TO-20. Does that seem possible? Did they put the narrow tires on other models? I grew up with tractors, just don't know much about Fergusons.
You might check on "TOP" of the dash between the steering column and the hood there should be a serial number tag. If it is still there get the number and on the left side of this page under Research & Info click on Serial Numbers then follow through to find the correct year.
(quoted from post at 02:58:19 01/09/15) This is not much to go on, but my uncle had a gray Ferguson tractor that had really skinny front tires. Seems like they were no more than 4 inches wide. I think it was a TO-20. Does that seem possible? Did they put the narrow tires on other models? I grew up with tractors, just don't know much about Fergusons.
te20 had 19 inch skinny tires and to20 has 15 inch wider tires. both wheels will interchange
Were the TO and TE series made at the same time? Did each have a special use it was designed for?
