Hey guys and gals I have a 49 TO 20 or 30 not real sure which one I have.I picked up a davis model 101A FEL for it.It came with rear brackets that bolt in useing the rear fender mounts on the rear axle.This is strait forward and done!
What hooks up to the front of the tractor? I got this bar mount that hooks into the front of the super structure of the FEL with a 3/8" plate looks like it would slide under the tractors front end and tie into those two bolt holes in the bottom of the tractors front plate? is that it? just those two bolts on the front and the two 1" pins in the brackets off the back axle housing?
Seems like there should be something more substantial to tie the FEL into the front frame of the tractor?
Thanks for any help y'all can offer,MIke.
