Remember a while back I posted about I was shopping around for parts for my newest TO-20 rebuild? This price includes everything, and its all quality parts, sealed power,delco,fel pro,gates,standard motor products,etc.... I bought a new ignition switch, gasket set,rod and main bearings,pistons,sleeves,water pump,thermostat,points and condensor,spark plugs,new valves,springs,valve locks,valve guides,thrust washer,clutch,pressure plate,throwout bearing,pilot bearing,input shaft seal and gasket, had the flywheel surfaced,crank turned, bought another carb and carb kit,oil and filter,radiator hoses,fan belt,and shellac and silicone. The grand total came to $774.92. I don't think that is bad at all considering everything I bought and had done. Since every piece is quality parts and new I shouldn't have to worry about the tractor for many,many years. The only thing it cost me was some time to sit down and cross the Massey numbers over.
