Hello,
I have installed a new electronic system in my Fergie. Few months back and it has been running well. Yesterday it quit and there is no spark. I suspect it is the unit or the ignition switch. If I run a wire from the positive post at the battery to the positive side of the coil would this eliminate the ignition switch and possibly prove either the coil or the electronics are at fault? The tractor is 12 volt negative ground.
Thank you in advance for any info.
