to35 carb spring
S/C BOB
I am needing the spring part #61-567 on Mikes carb site. I think it helps the float shut off fuel when the bowl is full. Thanks. Got him running about a month ago...So far I used it to pull wild cherry root out of the yard that was growing out of the top of the ground. It did fine.
The only spring that should be in the area of the float is to keep the needle in contact with the float so it does not jam in the fuel inlet.
Such jamming action would result in flooding.
As for that spring it should be part of a carb kit.
