TO30 12volt wiring diagram?
Kuebeck89
I recently got a Ferguson TO30 with the Sherman gear and have started rebuilding it. I bought the 12 volt conversion kit for it and it's time to start rewriting it. Does anyone have a complete wiring diagram for this? Also I bought a conversion kit with a resistor does this take place of the voltage regulator or do I need a new 12v one? Any help is appreciated.
The 12 volt conversion kits I've seen use a Delco alternator with built in regulator. If so you remove your old generator and regulator. The resistor is only used if you keep your 6 volt coil. You could use a direct 12 volt coil such as NAPA IC14SB without the resistor.
