I posted a couple of days ago on this forum about the TO20 that won't start because I think the ring gear may have shifted backwards on the flywheel.
Someone was kind enough to measure the distance from the mounting face of the starter to the front face of the ring gear.
The dimension he gave me is almost 3/16" shorter than the dimension on my tractor.
This leads me to believe that my ring gear did in fact move backwards, and I will have to split the tractor to try to get the ring gear pressed back to the proper location on the flywheel.
I've never split any tractor before, and all I have in the way of a manual is the I&T manual.
That manual is at best very limited in information about any splitting procedure.
I've noticed on this forum, some good pictures and information, such as from Jeff-Oh about how to do a split the right way without loosing any important body parts in the process.
I am naturally at the moment quite poor, and was wondering if any one (such as Jeff) could lend me a hand in trying to get this job done.
Even if someone could tell me what would be the best manual to get me started, along with some inexpensive means to support the two tractor halves.
I have two 2 ton floor jacks, two bottle jacks, and a 3 ton-41" farm jack.
My barn floor is hard packed gravel and dirt, but I do have large sheets of plywood.
Once I get the tractor apart I need to know how to pry the ring gear off of the flywheel so I can press it back on. At this time I only have a small propane torch from ACE. Do I need more to heat up the ring gear to remove it and put it back on? Is there any way I can secure the ring gear better than just pressing it on the flywheel? Maybe a couple of well placed screws would work?
I apologize for the long winded post, but would appreciate any help, manual text, pictures, plans or any information at all.
I thank you all in advance and for all of the help I've received in the past!
This forum is really such a great gift for the financially challenged or anyone that uses or loves tractors.
Jack
Jack
