Hello,
This past weekend, I started up my 1957 TO-35 to move some brush. It has the gas engine. After running for a few minutes, I noticed water pouring out under the tractor. It was coming out of about a 1 inch diameter hole located in the side of the engine right behind the carburator.
The radiator, hoses, and water pump were replaced last Spring and the tractor has run fine since then. We have had some freezing temps lately, but the tractor had anti-freeze. After shutting the tractor down and letting it cool off, I tried to refill the radiator, but the water poured out of the hole in the engine about as fast as I could pour it in. I checked the engine oil for signs of water and found none.
Is there a seal located within the engine that may have ruptured that would allow the water to just pour from the engine like that.
