Have any of you experienced a slow lift action on a cold morning.
I drained and replaced the oil in my 1957 TO 35 last summer. Filled sump with old school oil, GL-1 90 weight mineral oil.
Lift worked fine until it got cold, now I was having to wait a few minutes for the lift to start working after a cold startup. After the tractor runs a while the lift works fine.
So to help the old girl out on a cold morning, yesterday I added a quart of Lucas oil stabilizer to the hydraulic oil sump. Used the tractor for a while to insure the hydraulic oil was mixed well.
This morning I started the tractor up, then raised the lift lever, in a very short time the lift started raising up, a marked difference in time.
So I think the Lucas oil stabilizer may have helped the old worn hydraulic pump, maybe keep it running a few more years.
That 90 weight mineral oil GL-1 hydraulic/transmission oil gets fairly thick during cold weather.
Later after I had changed the hyd/transmission oil, I saw where you could buy non-detergent 10w30 oil from home depot. Only place I have even see it.
If I had know that at the time I changed the hydraulic/transmission oil, I might have bought my oil from them.
Buying the Gl-1 from NAPA was not cheap.
But I wanted to use a non-detergent oil in the hydraulic/transmission system.
