is there a correct procedure ???
s19438
how do you guys clean the magnetic drain plugs from a ferguson tractor?
I run them under hot water and use a eating fork to clean out between the magnets then blow off with air gun.
A rag soaked with heavy oil, then a tooth brush with gas, then air pressure, I guess that why nowdays mechanics at a dollar a minute throw out the old ones and make you think the threads were striped.
