I'm trying to bring a TO-20 back from the dead for a friend and
having trouble getting the oil filter cover to seal to the pan.
Pan and cover gasket surfaces are spotlessly clean, new gasket.
It doesn't leak much, just a drip once every 5 to 10 minutes or
so, but that's cold and it only has about one quart of oil in it to
check for leaks.
If I rotate the cover it gets better or worse depending on position.
The cover doesn't seem to be damaged from hitting anything,
so I suspect it may be warped from over tightening.
I don't want to buy a new cover, at least not until we see if/how
it will run, but I figure it will leak worse once the oil is warmed up.
So I could run it as is and buy a new cover when ready, use
some sealer on the gasket (which I would prefer not to do)
or I was thinking of using an O-ring in place of the gasket.
Local parts store makes 0-rings any size and thickness wanted.
Good idea? Bad idea? Other suggestions?
check for leaks.
