blackimpala
New User
I have a TO 20 and just had the crank reground put new main and con rod bearings. Turned the engine over with spark plugs out got oil out of fitting on side of block, forgot to hook up tubing to gauge. Had the engine running for about 20 min. shut it down then would not turn over again. Disassembled again found con rod bearings bad, seems to get oil to the main bearings but not con rods. I never had oil pressure but suspected bad gauge now not so sure. Thinking oil pump now but read they are very reliable.Thinking it is pumping but not enough pressure. Took cover off and nothing looks bad. Oil passages in crank are clear.
Any help or suggestions will be welcome.
Floyd
Floyd
