FE35 Petrol
2tractors
Here is a pic of the 35 as it waits on partial teardown for low compression. There is a valve on the intake. Anyone know what that is all about?The head is now in the machine shop and the pistons cleaned up with a rag.
There was a dedicated adapter made for the same purpose ( milking machines ] for the TE20 tractors . This went between the manifold and carburettor.
The adapter kept the milking machines milking the cows when the electric went out. Milking machines use vacuum to milk the cows. This was after the farmer quit doing it by hand.
Forgot the name of it, but the hose from this tap went to one side of a sliding valve on the top of the milking machine can, there was an air tight seal around the top on the can, so the milk came from the cow's tee tee, into the can, but could never get up the hose into the pump, or in your case, the intake manifold. It wasn't just emergencies, some back road farms didn't get phone poles till the mid 60's.. the good ol days huh???
What's that yellow thing back there? a target? cool!! Rifles or handguns??
The fe was outside, the 33 inside.Put rod in neutral an let it roll downhill and way out of the way. Hand pushed the fe backwards an also downhill,scary, then used the 50 to pull fe inside.
Another fine use for a handy 50!! World's coolest tractor!!!
I think any car from the early 30's were the best looking thinks to ever roll down a road. Those 33-34 Dodges just got a mean but classy look to em... even yellow ones...
2tractors:
Could you give me some info?
I have misplaced (lost) the 4 bolts that hold the fan on the front of one of my FE-35 petrol tractors, and can not remember how long they were. Are they 1/4 fine thread? I could take the pulley off and take it to town to get the correct treaded bolts, but it you do not mind the info would save me the trouble,
thanks
Lots of stuff there. I saw the 4 or 5 position
switch that's on my dash I guess its for lights.Wish
I could order the lights from someone.
here is a pic. 3 inches long and fine thread.Before anyone asks that's a 65 and 50 bolster underneath.
(quoted from post at 15:30:36 11/16/14) I can supply a proper British lighting kit......
Sam
I don't mean to hijack the thread, BUT: Hey, Sam! Long time no see. Welcome back. Hope you've had a good fall.
