ferguson tractor jack
This message is a reply to an archived post by s19438 on May 23, 2012 at 14:35:55.
The original subject was "ferguson tractor jack".
ok guys, I would like an answer to this asap please. I have TWO of these which are about to be sold.
#1 has a length of 24" from bottom of cup to ground.
#2 has a length of 21" from bottom of cup to ground.
Which goes with 20 or 35.
Thanks. Rod.
Most the time the small cup goes on the 20. Does front bracket have the points(on bottom) that holds it in place on ground? This always goes on the 20.
At the FENA EXPO this year one member had his jack with the small cups under his 35 and demonstrated it several times during the Expo. I bought one with the small cups and I plan on using it on my TO 35. My front piece has the points that go into the ground and a small cross on the top that I am guessing goes in a hole somewhere.
(quoted from post at 11:08:49 11/11/14) Most the time the small cup goes on the 20. Does front bracket have the points(on bottom) that holds it in place on ground? This always goes on the 20.
Thanks. Yes my small one, does NOT have a chain and the front bit has the two POINTS.
