watersteps
Hi Guys,
As I am getting ready to install my new or rebuilt engine in the 35 I keep finding things that need replaced.
This request is for the plate that bolts to the front pulley on the engine and has female splines in the center. The plate has 4 holes that have rubber vibration sleeves in each. Next is the shaft and it has male splines on one and a key way on the other. The key way end is fitted with a 2 hole flange that bolts to the hyd pump for the front end loader..
The plate is 4 inch OD and about 5/8 inch thick with a 1 and 3/4 inch stub that sticks out the front for the splines. The bolt holes are 2 and 3/4 inch on center across the center of the plate.
The shaft is 3/4 inch OD and 13 inches long with one end having 1 and 1/2 inches of splines on the one end.
Both the plate and the shaft are worn too much to reuse.
Anyone known where I can get these parts.
The loader on the front is a Shawnee if that helps.
Thanks for any help you can offer.
