watersteps
Hello everyone, I have a 1955 TO-35 Ferguson Tractor. My problem is the engine. I drove it and it ran great, no smoke, no noise, but it used 2 quarts of oil every hour. It had a real bad rear main seal leak, so I split the tractor and checked it out. Seal was rock hard rubber, checked the mains and the rear main bearing looks bad. Crank will need ground. Checked the rods and number 1 and 4 are real bad, rod itself must be re-sized. Block is great no cracks, head is fine. Rebuild costs will run me well over a $1,000.00. So I am looking for a good used motor to replace mine.
This is my problem, I cannot find any anywhere. Is there a secret place that is known only to a special few? Or maybe there are none out there to be bought.
What about putting another engine in the tractor?
Thanks for any help anyone can provide.
