carb settings
Seems I've seen the settings for the mixture screws for the carb for a starting point. Putting on a new rebuilt on my TE 20.
Thanks to all
Take screw driver and screw air(small on side) down and then 1/4 turn open, large(gas) about 1 1/2 turns open is where I start. Then fine turn it. All tractors may be a little different, I even seen some where the air is turned all the way down.
(quoted from post at 10:58:05 10/21/14) Seems I've seen the settings for the mixture screws for the carb for a starting point. Putting on a new rebuilt on my TE 20.
Thanks to all
The Ferguson shop manual says 7/8 turn for the idle mix screw and 1 1/4 for the main needle
my understanding is the screws adjust fuel not really air so keep that in mind when turning the screws
Remember the main jet adjust fuel. Screwing it out increase main jet fuel flow and enriches mixture. Idle mixture screw adjusts idle airflow. So screwing it out leans the mixture.
