RWILLIAMS531
New User
I HAVE A TO30 FERGUSON TRACTOR WITH NEW CARB ON IT.
THE TRACTOR IS GETTING GAS TO THE CARB. AND IT WON'T START. AFTER CRANKING ENGINE OVER SEVERAL TIMES THE SPARK PLUGS AREN'T EVEN WET WITH GAS. I HAVE ADJUSTED THE CARB. ACCORDING TO THE DIECTIONS FOR THE NEW CARB. WHAT COULD IT BE? THE TIMMING, TROUBLE WITH GOVENER, I ALSO REPLACED THE 6 VOLT COIL. COULD IT BE THE VOLTAGE REGULTOR?
THANKS YOU FOR YOUR HELP.
