will this carb fit my to-35 that
I have swapped carbs on cars and had more problems with vacuum leaks from not plugging all the unused lines. That said what you need to know is the bolt holes center to center are the same the hole in the center not too large or small. The bolt holes not 90 degree off. The linkage on the same side when bolted to the intake. and will the hose to the air cleaner will it fit. IF all that is good the only problem would be adjusting Idle and rich or lean.
Ypop
Ha. That's the place I got the kit to rebuild the CAV pump on my famous 23C diesel. Collecting carborators is an investment more than an addiction. Sometimes it's a pain to switch the inlets and direction of the levers and cables- how does it compare to your old one?
the old carb is a carter and it is pretty much shot. at least as far as I am concerned. the mounting studs look to be the same distance apart. the linkage would be my biggest concern.
ya know a few years ago i "got rid" of four M/S carbs thinking I would never need any of them again............
(quoted from post at 16:44:48 10/09/14) the old carb is a carter and it is pretty much shot. at least as far as I am concerned. the mounting studs look to be the same distance apart. the linkage would be my biggest concern.
Yes it should bolt up, of course you will have to reset the governor and possibly modify the end of the fuel line. If it doesnt fit you can get your money back thru paypal. Its listed as fitting a 35 if it doesn't... get a refund, but it will fit. Remember though that those carbs are not real Marvel Scheblers. They are a pot metal copy of a Marvel Schebler.
