I have done a few MS carbs in the past but never a carter. this one taken off a to-35 is all aluminum or white metal. either way the carb body and top is non magnetic.
the round gizmo in the middle is corroded/chewed up around the edges. is that a problem as I have not seen a replacement part anywhere.
also at the narrow end of the carb somebody used permatex along with the gasket to make a seal. I am thinking the carb may be warped ????
thanks.
thanks.
