carter carb ID
s19438
want to make sure I get the correct rebuild kit.
what model carb. is this?
thanks.
(quoted from post at 16:24:27 10/06/14) want to make sure I get the correct rebuild kit.
thanks.
It's a Carter UT. Can't get many parts for them anymore, and check them for warpage. Those carbs were also used on Farmall Super A's and Super C's. I have one of them.
http://www.tractorpartmart.com/us/ih-carb-repr-kit-p11362.html
ok I answered my own question. but it seems all the repair kits I looked at do NOT include a float. what's up with that ?
(quoted from post at 00:50:16 10/07/14) ok I answered my own question. but it seems all the repair kits I looked at do NOT include a float. what's up with that ?
You can't buy a float for them anymore unless you find a NOS one.
What's wrong with your float?? Mine had on side bent inwards and I desoldered the little hole on the bottom,injected compressed air to blow it back out and then resoldered the hole, worked out great.Mine on the standard gas was either brass or copper.
