Just rewired the 4 Delphi HDS 317 glow plugs, using 10 gauge multi-strand copper with multi layer cover insulation. Did both the hot and ground sides in a series manner, ground connection under ceramic insulator closest to glow plug core, collaring the brass center, and using metal top of glow plug for the hot wiring with the aluminum finger nuts holding the power wiring to the center threaded post, which compressed the ceramic insulator causing a tight fitment for the ground wiring path. Ground wiring ends at the top front bolt on the oil filler neck, cleaned and tight.
Resistor under dash turns a bright reddish orange, yet with glow plugs wired and placed on an insulated mat next to engine with ground attached to bolt in top front of oil filler neck going into the engine block, the glow plugs were warm, not hot, but did not glow, and indications of the hot feed wire from resistor under dash was melting at its' connection to that resistor, (bubbling insulation).
Have I wired this wrong, as I think the glow plugs should show a color change similar to the resistor under dash?
Second question should I be using larger than 10 gauge for the primary feed from under dash resistor to first glow plug?
