Clutch Release Bearing (Throwout Bearing) TO35 Diesel
DrLoch
Clutch release bearing seized up this past Sunday. This site offers a couple of different ones. Anyone know which one would be the correct one so I can order it and get moving in this direction? It's a TO35 Diesel SN: SDM 203510, it has the dual clutch.
This site has release bearing 892862M2 listed for $24.75 for single and duel clutch. The $124.16 bearing they have states it is for single clutch tractors and is part number 833085M2. Not sure which single clutch assembly needs that expensive bearing but I hope I never need it!
Dan
Got it out today. As you can see from the picture it smeared the heads of the bolts on finger... Going to use acorn nuts loctited to 3/8-24 studs to replace them then reset the heights. The clearance adjustment for the 2nd disk was incorrect also, should be .090 it was .040 at best.
