While the weather was nasty outside today I thought I would compile a list of part numbers for TO20's and TO30's using a Delco distributor. These are Borg Warner and Napa part numbers. There are cheaper versions of these parts available but I will not use them and I encourage others not to use them as you will only have problems.
Distributor cap: Borg Warner C150, Napa RR145
Rotor button: Borg Warner D10, Napa RR83
Heavy Duty Points: Borg Warner A40H, Napa CS763A
Regular points: Borg Warner A40V, Napa CS63A
Condensor: Borg Warner G102A, RR174
6 volt coil: Borg Warner E1, Napa IC7
If you want premium Blue Streak points and condenser their part number is
Standard Points: DR2227XP
Standard Condensor : DR60
Walker brand carburetor kit is: 778-505A
Borg Warner A40H
Blue Streak DR2227XP
I did this because I didn't see a parts compilation on the Ferguson board anywhere for local parts stores.
Borg Warner A40H
