TO20 Dead generator
gene in la.
New User
I have aTO20 with a generator that's not putting out any voltage! Have replaced voltage regulator! Checked all wiring! My question is should I have the generator rebuild for $100 or get a conversion kit to 12 volts for $100!!! Any help will be appreciated!!! Thanks Gene in La.
Out of curiosity had you polarized the regulator? If you hadn't
you will not get a charge with a new regulator.
Otherwise yes, an alternator conversion will save a lot of
headaches and they make 6 volt pos ground alternators.
If it's a show tractor, keep it original!
If it's an occasional use tractor, the 12v conversion will work well.
If it's a daily working tractor expect some starter troubles. The 12v on a 6v starter is mechanically hard on the starter and flywheel gear IMHO.
No I have tried polarizing generator, but not sure I did it correctly, please explain again the correct way! I sparked from battery to generator terminal?
There are a lot of threads to polarizing. As I understand on a pos ground system jump a wire from the neg terminal to the "A" terminal on then generator and just tap it to get a spark.
Tom H. has it right. With the tractor off run a jumper wire from the negative terminal and touch the arm stud on the generator. You should a see a spark when you touch it to it. If you look closely on the generator case you should see an A stamped into the case identifying which one is the armature stud. As far as the generator vs alternator debate, I'm all about originality. I do 90% of my farm work with my TO-20 and it is still 6 volt with a generator. I crank it in below freezing weather and have no problems. Generators have gotten a bad rap over the past few decades but it's not the generators fault. Very few people stop and think about how unmaintained there charging and starting system is. These $20.00 and $30.00 voltage regulators aren't much count. A good one will run you around $60.00 with a lifetime replacement. Make sure you have a good ground where the regulator bolts down.
I have a similar dilemma, the pictures attached show what came off my to20, it never charged properly, I got it like that, I was going to clean it up lube the bearings and zap it, but that silver thing looks like its regulator, the one post that has no wire connected had a wire running directly to the battery post, negative, ( I believe or at least it should, it is a positive ground ), so what to do?
option 1 is to get the regulator and see if I can get it wired properly and working, I have a fairly new starter, and a ring gear that comes off so for the longest time I used the hand crank and charged the battery at night just to see if the rest of the tractor holds up, plus I had work to do with it and time was of the essence.
if this don't work I guess I am out $60 and looking at converting it, I think the kit was $150, not sure if it has everything I need, something about a resistor to protect the original coil? I'll need a battery that's for sure, maybe a new coil to be safe, it is starting to add up so what to do,
I was even debating getting a junkyard alternator, make some brackets and run the headlights in series with the battery, keep everything 6 v otherwise, in theory it should work but I wonder why this is not a common fix, I have not read of it elsewhere.
I still have to see about the flywheel, off topic, I will have to split the tractor, I am tempted to weld the ring gear to the flywheel and be done, some recommend getting the revised flywheel, but than I would need a clutch alignment tool, I have a couple from other automotive sets, but likely wont fit, clutch is good so I would not replace it thou in the past I have replaced everything I could when I open something up, this means the rear main too, which I read is a rope,
ohh what to do?
I am not trying to restore the thing just get functional, I got more work this coming summer, on a budget if possible, I am really trying not to get carried away and make a big project out of it ( dam it no pics yet, I'll try and upload them in a bit )
http://www.dbelectrical.com/p-7754-regulator-15-amp-output-agricultural-industrial-marine-8040-6158.aspx
this is what I have for a regulator, it is screwed to the generators case, the A post is grounded to the generators case, and the F post goes to this regulators post, from the other to the battery, this is unlike the wiring I saw for these tractors with the proper regulator.
I suppose it could work but it doesn't seem it is wired right, I'm no expert but why would you ground the armature, guess I'll look at those schematic again
well I got a new regulator today, its the same part number as the one listed on this site thou I got it from a different site along with an alternator for a different tractor, and I got to say holly moly this thing is huge in comparison with the dinky one that my tractor came with, not to mention I am not sure about the previous wiring schematic.
so I guess I'll be rewiring this tractor according to the original schematic, I believe the proper location for the regulator is by the battery tray, and from what I read a polarizing is in order once properly wired, we'll see how this goes.
