Ferguson 30
More than likely it is, but it wouldn't hurt to compare the serial number with those on the left side of this website. Also, the to30 had a z129 engine, while the to20 had a z124 motor.
Correction IH the TO 20 used the Z 120 engine. Kalvo these cast numbers can be found below the Engine oil dip stick. The serial number tag for the tractor if still on it will be on "TOP" of the dash between the steering column and the hood.
